Sbs-01tas
Sbs-01tas
UGH!!
I can't seem to get the TAS (Pitot) to show anything on my 18MZ... I just updated the software (2.7.2 I think)...
assigned it to slot 16.. (Instructions implied it would automatically find slot 16???)
Also had to input the ID number..(Not indicated in the instructions)...
I have an 18MZ...not WC...
HELP!!!
HELP!!!
So you re-registered the sensor? I've also found that it is good practice to re-link the TX/RX after adding new sensors. And what the heck do you need airspeed for? See how slow you're hovering?
I did a "Register" with the sensor powered up and plugged into Tx.
This put the sensor ID # next to the next available slot. The slot is blank though.... Select the slot, choose True Airspeed, close and re-enter the TAS ID... unplug battery and TAS from Tx and plug into Rx... power up the Rx and TAS shows an airspeed!!!
I next "Registered" an optical RPM sensor.... plugged a simple "Y" connector into Sbus2 and both telemetry sensors seem to work!!!
Malcolm H (03-21-2021)
I have the T6K V2 as mention in the photo and the R3006SB receiver
From the manual you posted I read page 75 which guided me to page 83 where it states:
"Sensors that can be used with T6K:Futaba SBS-01T/TE, SBS-01RO, SBS-01A/02A, SBS-01C, SBS-01V"
The is no mention on SBS-01TAS
