Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
R7006sb
Old 03-11-2019, 10:59 PM
riot3d
Default R7006sb
Hi,
Normally, I'm using a R6008SB with the following servo allocation. They are regular BLS servos, not the SB version:-
Ch. 1 - Ele
Ch. 2 - Ele 2
Ch. 3 - Rud
Ch. 4 - Ail
Ch. 5 - Ail 2
Ch. 6 - Thr (Glow)
I would like to use a R7006SB with two S. Bus servo hub cable with decoder - one for two ele & one rud servo on the tail, another one on the wing for both of the ail servos, then plug both into a 4 way terminal box, then to the Rx.
However, on the R7006SB, on what mode A, B, C or D so I can have the same kind of channel allocation as the R6008HS? I would like to plug the thr servo directly onto the Rx. Or, should I also plug the thr servo onto the terminal box & just assign channel 6 as usual? I have no problem with the R7008SB, but just can't the R7006SB to work like the R6008HS. I assume the R7006SB is also a 8 channel receiver like the R7008SB under S. Bus application?
Thank you,
Adrian
Old 03-12-2019, 08:21 AM
FUTABA-RC
FUTABA-RC's Avatar
Why can't you simply keep it in Mode A (default) and plug the servos in as shown above? You can simply use a normal servo "Y" to connect in the battery?
No need for decoders, etc. then.
Also, the nomenclature can be confusing.
The R7006SB RX is a 6-channel receiver, but using S.Bus it can do the max number of channels your transmitter can do.
The R700*SB RX is an 8-channel receiver, but using S.Bus it can do the max number of channels your transmitter can do.
Old 03-12-2019, 10:36 AM
riot3d
Just wanted to use S. Bus
Old 03-12-2019, 11:47 AM
FUTABA-RC
FUTABA-RC's Avatar
Well, you can, but you will need to change some things. It seems overly complicated but if you really want to do it this is how I suggest:
RX in Mode C
Gives channels 1,2,3,4,6 & S.Bus
Ch. 1 - Ele - Decoder 1 - Assign servo channel 1
Ch. 2 - Ele 2 - decoder 1 - Assign servo channel 2
Ch. 3 - Rud - decoder 1 - Assign servo channel 3
Ch. 4 - Ail - decoder 2 - Assign servo channel 4
Ch. 5 - Ail 2 - decoder 2 - Assign servo channel 5
Ch. 6 - Thr (Glow) - plugs into Port #5 on the RX.
Plug battery into any open port
Plug S.Bus into Port #6 on RX
Ports 1, 2, 3, 4 will not have anything plugged into the.
I would take the 2 decoders and plug them into a "Y" then into the RX Port #6
Again, seems overly complicated when you can simply plug the channels as assigned into the RX directly, but if you want to do S.Bus this is how I suggest.
