S.Bus and Telemetry
S.Bus and Telemetry
I'm sure this has been asked before but search results are letting me down.
I'm running a powerbox mercury that is sending S.Bus signal to my S.Bus 2 port. If I want to use telemetry, am I meant to move the Powerbox to the S.bus port and run sensors to the S.Bus2? If so, how do I tell my receiver to use S.Bus instead of S.Bus 2 for the powerbox?
Thanks!
Thanks!
The Mercury should be connected to the normal S-Bus port.
If you then want to use the Teleconverter for telemetry, then this is connected to the S-Bus 2 port.
Just make sure that your receiver is set to the correct mode of operation for S-Bus to be set to port 8.
modtron
Oxford UK
modtron
Oxford UK
