Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Great Planes/Futaba
Idle Switch
Old 04-08-2019, 02:15 PM
Sukhoi_Madness
Sukhoi_Madness's Avatar
Default Idle Switch
Hi guys,
What is the correct methodology on a 14SG to program a switch for high and low idle, i.e. low idle on the ground and on final approach and high idle during aeros?
If you can point me in the right direction I can probably work it out but I'm not sure what the best way to do it is.
Old 04-08-2019, 07:15 PM
FUTABA-RC
FUTABA-RC's Avatar
There are a couple of ways.
1) use a throttle->throttle mix. Keep the curve the same except at the bottom end. Turn mix off to get lower idle, turn on for higher idle.
or use idle down
2) Futaba's "Idle down" is really more like an "Idle up". When it is ON the idle is lowered, when off it is set to where ever your idle trim is.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
