18mz V tail mixing
18mz V tail mixing
Mixing "motor to elevator" on a big glider (to trim nose down under power), the program mix will only mix half of the V tail (elev servo).
It only looks at the raw elevator servo instead of the V tail elevator function ( both elevator and rudder servos).
To get the tail to work I have to use a second program mix "motor to rudder" to get the other tail half to mix.
Is there a better way of getting the V tail elevator function to mix with motor ?
In the menu where you set the slave function you will see a button just the the right of the slave Function name. It will be blank, but can be toggled "+". "-". change that until both elevator/ruddervators deflect correctly
