help on futuba t9chp radio
Hi,my radio is in heli mode,alirons are channe1 and chanel 6 [pitch],everything is on 140 percent,no mixes.but alirons turn left twice as far as left. Im stumped any help will be greatly appriciated,ive worked on this for weeks plse. Help brett P.S. IV'E E-MAILED FUTUBA-USA 4 TIMES IN A MONTH WITH NO RESPONCE IM READY TO CHUCK EVERYTHING I HAVE FUTUBA,SERVOS GYROS RADIO AND TELL EVERYBODY ABOUT NON EXISTENT CUSTOMER SERVICE
First, tell me more about your installation.
Are you using a gyro, if so, which one?
What servos are you using and are all the arms the same length?
I need more info than what you have written so far.
hi,this is a flybar heli,i'm using a 401 futuba gyro was using futuba servos,but i'm using kst d-215 servo's now,i upgraded to digital.yes measured swash control arms,there the same.when i took servo's of heli and put side to side you can see it moves twice as far left than right and it shows this in servo menu in radio..im using a 2.4 module in back of radio..
Hi no there not ailerons only lets you do one side only,you have to go to channel6 [pitch] to do other side of turn..both are on 140 percent,i tryed 100 but was the same left twice as much than right brett
What did you select for Swash Type, when setting up the model in Model Type menu ?
H-1. H-4, HE3, HR3, H-3 or H-4X.
What happens if you start again with a new model file ?
modtron
Oxford UK
modtron
Oxford UK
Trying a new model was my next suggestion. But again, is this what you actually see on the swash or only in the servo monitor. And when checking the throw is the gyro in normal mode and not AVCS?
If the actual control is moving as expected I really do not pay much attention to the servo monitor, especially when a gyro is involved. Actual control motion is the most iportant thing.
hi everyone,i wan't to thank everyone for there help,thank you futuba for trying to help.. But i know when to quit,it's just not worth all the aggravation.i'll use this radio for sailplanes,were there is just ailirons. I really appreciated all the help sincerely brett
