Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
16IZ with 7008SB and7108SB
Old 09-23-2021, 11:08 AM
killerG
My Feedback: (32)
Default 16IZ with 7008SB and7108SB
Thinking about getting a 16iz to replace my old 12z. I already have a R7008SB RX. If I get the 16iz with the R7108SB is it possible to set it up in a plane as the R7108SB will be ch 1-8 and the R7008SB can be 9-16? Obviously I would just use fasst mode. And would you need a battery for each RX? I was thinking that I needed to get the R7014SB but If using the 2 RXs will work, I donít have to.
Old 09-23-2021, 11:31 AM
FUTABA-RC
FUTABA-RC's Avatar
The dual separate receiver set up with split channels only works on FASSTest. You can link 2 receivers in FASST but only get the same channels out of both.
I do not think you can mix/match the 7108 and 7008. If using 2 RX I always recommend posering both from both batteries.
I use the 7014 in a couple of planes. I like it.
What model are you setting up?
Old 09-23-2021, 11:46 AM
killerG
My Feedback: (32)
Setting up a Seagull Spitfire with smoke. 11 channels if I donít ďYĒ anything. I donít like to use Ys at all.
Old 09-23-2021, 11:56 AM
killerG
My Feedback: (32)
Just noticed its a R6208SB that I have, not a R7008SB so no it wonít work. I guess I will just get the R7104SB.
Old 09-23-2021, 12:36 PM
FUTABA-RC
FUTABA-RC's Avatar
I'd just go with the 7014 as well. Remove complexity where possible. Run 2 packs into the RX and go fly.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
