Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
14SG battery fried
Old 08-23-2022, 10:32 PM
Javier-RCU
Javier-RCU's Avatar
Default 14SG battery fried
After five charging hours with the 14SG original charger, I diconnect the tx in order to do some adjustments in a plane. When I pressed the ON button the low battery alarm begun to blink and the charge level was near 5.2 v. Once opened the battery compartment, the battery was very hot with a burn smell. After some test with my charger is clear the battery is fried.
My 14SG is almost new. ¿What could be happen here?
Old 08-24-2022, 08:08 PM
FUTABA-RC
FUTABA-RC's Avatar
To be clear, you were using the TX charger that came with the radio, correct?
How low was the battery when you started charging it?
It is possible that the battery is defective, or the charge is not functioning correctly.
Old 08-25-2022, 06:10 AM
Javier-RCU
Javier-RCU's Avatar
Thank you for your reply. Yes I was using the original Futaba TX charger. The charger was diagnosed and is ok. I decided to charge the battery when the low battery alert begun to sound while I was making some adjustments in my plane.
Five hours later I decided to continue with my plane setup and discovered the battery damage.
Old 08-25-2022, 06:19 AM
FUTABA-RC
FUTABA-RC's Avatar
I suggest you open a service ticket and return the TX, battery and charger to be looked at.
https://futabausa.com/repairs/
