Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Proud owner of 72mhz Futaba radios, but......
Old 01-11-2023, 02:00 AM
Joel308cal
Default Proud owner of 72mhz Futaba radios, but......
So, I've been flying since the mid to late 80's with 72mhz Futaba radios and have yet to experience any issues with them. I currently have a 6XAs PCM and a brand new, never used T9CAP that I plan on making my primary radio for my 60 size pattern planes. It currently has the original plug-in module and I was made aware that I can use a 2.4g module with appropriate receivers. If I decided to get a 2.4g module which one would you gents recommend? Which receivers would be good to get? Would I be able to fly a drone with the 2.4g module? Thanks.
Old 01-11-2023, 05:24 PM
J330
The DSM8 is a popular choice because it will bind with a lot of aircraft and it's half the price of the Futaba TM-7 module,
pretty hard to find and costs more than the 9CAP radio does.
You can pick up a new DSM8 2.4 Ghz module for $75 shipped on Ebay from time to time.
I am staying with the 72 Mhz modules instead and use the same 9C radio as you have.
Old 01-11-2023, 07:51 PM
Joel308cal
thanks for the info bud. Much appreciate it.
Old 01-12-2023, 11:49 AM
Dick T.
My Feedback: (243)
Unless you just want to get into 2.4ghz and there are no restrictions locally to 72mhz, stay with what you have. With 2.4ghz dominating the radio world there is virtually zero chance of interference now on 72mhz. Futaba PCM is probably the most bullet proof protocol on 72mhz, even when 72 was the dominate frequency used.
As mentioned previously, a DSM8 Spektrum module works in the 9CAP and operates almost all Spektrum receivers, except some most recent and newer BNF airplanes. Futaba's TM-7 or TM-8 FASST modules operate all current sport level FASST receivers reliably. While costing more, when they do pop up for sale, they work trouble free with the 9CAP.
I use both 2.4ghz and 72mhz with my Futaba transmitters that are module based. The interchangeability provides a lot of flexibility depending on flying site locations and frequency allowance or restrictions.
Your 6EXA and 9CAP are among the best systems Futaba produced in 72mhz. Use them until they croak!
The following 2 users liked this post by Dick T.:
curtthedirt (05-08-2023), Joel308cal (01-12-2023)
Old 01-12-2023, 05:15 PM
Joel308cal
in all honesty I don’t want anything having to do with Spektrum. I’d rather fork over a bundle on a Futaba module. Thanks for the insight though.
Old 01-13-2023, 10:59 PM
FUTABA-RC
FUTABA-RC's Avatar
Good info in the posts above. Quick reminder this is the vendor support forum and not the open discussion forum.
