BLS671SV use in jet airplane
Hi.
Looking for servos in my H9 MB-339. The manual calls for Spektrum A5080 servo.
The Futaba servo that I have found with similar spec and dimensions is BLS671SV. However it is listed as a car servo in the catalogue, although the manual does mention this specifically. The manual does say that it is for models with electric power train only.
So the question is, any reason not to use this servo in a jet model?
The main reason it is considered a car servo is because the deadband on surface servos is very tight which is not desirable on an airplane.
If you can program a little wider deadband it should be fine.
What feature makes this your choice? Speed? Torque?
What makes it my choice is because the manual calls out the Spektrum A5080 and the cutouts is ready for a servo of this size.
I have very good experience with Futaba servos and not so much experience with Spektrum so just feels more comfortable to go with something from Futaba,
Comparing specs
A5080 0.11 sec/60 deg @ 7.4V;118 oz-in (8.5kg-cm) @ 7.4V Size 15 x 36 mm
BLS671SV 7,4V: 0,10sek/60, 8,3 kg Size: 15 x 33 mm
Comparing specs
