Futaba 149DP & S9206: 6V safe?
Hello guys!
I own a Futaba 149DP receiver that I'm used to run on 4.8V: does it support 5 elements batteries (i.e. more than 6V...)?
Also, I've purchased a servo 9206 and the instructions say that it must be run on 4.8V... why? Anyone has tried 6V on it?
Thank you all for the replies.
RE: Futaba 149DP & S9206: 6V safe?
Thank you no glo!
Do you mean that you use some voltage regulator or just a 5 elements battery?
Any ideas why Futaba say "4.8 V only" on 9206 servos instructions?
The servo will not accept other than a 4-cell pack because it was not designed for more. If you try it, you'll ruin your servo.
The receiver, itself can handle a wide variety of voltages because of its internal voltage regulator, but any voltage you apply to the receiver goes to the servos, so you can't just plug in anything.
