Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
6ch electron with 9c ?s
Old 06-27-2007, 11:21 AM
walton
My Feedback: (24)
Default 6ch electron with 9c ?s
Ok I need a little help here.
I am trying to run two aileron servos and two elevator servos with a 9c and electron 6ch rx without using Ys or a reverser. Any or you guys know how to set this up?
Old 06-27-2007, 02:53 PM
Krysta
Default RE: 6ch electron with 9c ?s
Hi walton,
You would first simply need to set up Flaperons in the normal channel 1 and channel 6. Next you would want to go into Aux Channel in your basic menu, go to CH5 and make this Null.
Now go into a Pmix, make it Active, set the Master to Elevator, and the Slave to Gear. Leave Link off, but turn Trim On. Leave the switch at Null and then set your rates at +100% both ways.
You now have dual elevators, one on channel 2 and the other on channel 5 with no fear of hitting your gear switch and accidently deflecting your second elevator.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
ORIGINAL: walton
Old 06-28-2007, 08:30 AM
walton
My Feedback: (24)
Thanks I will try it!
