IMAC Plane Setup
My Feedback: (25)
AR
IMAC Plane Setup
OK... I just ordered a 12Z. I'll be putting the latest version on it when it shows up.
I want to get my IMAC plane set up quickly, but the manual doesn't really have an example of what I want.
I will be using the Multiplex PPM RXs I already have in the plane... not changing them out at this point. One RX is 9 channels and the other is 12 channels.
With the update that allows 12 PPM channels, will all 7 wing types also be allowed?
So, I have 2 servos per aileron. I want each plugged into it's own TX port.
-What is the best way (wing types, etc...) to make sure both servos get exactly the same signal at the same time?
I also have 2 elevator servos... it would be handy to have them on seperate channels...
-What it the best way to do that in light of the aileron servo requirements?
Jason
Jason
RE: IMAC Plane Setup
You would want to set up the airplane with the "2 aileron" wing. That will give you a setup with Aileron and Aileron 2. Go into the Function Menu and then set up Aileron3 and Aileron4 on channels 7 and 8. Set the stick and trim of each to the aileron stick and trim. Now you set up your left aileron using Aileron and Aileron2, and your right aileron using Aileron3 and Aileron4.
Set up each servo's movement in the ATV menu. Do not adjust the servos in the AFR menu. You use AFR to adjust the aileron Function, and the ATV to adjust each channel's centering and throw.
Your elevators will be on channels 1 and 2. Again, set the throws and centering of the channels in the ATV menu.
My Feedback: (25)
AR
Thanks!
Will differential and mixing function properly if set up as such?
If Aileron is normally the left aileron and Aileron 2 is normally the right aileron and I dial in differential, Aileron 2 would move less with left stick and vice versa for right stick.. this would cause binding if both were on the same aileron. Does the radio recognize the change in setup when adding the extra aileron channels and change the way it applies differential? (BTW... this is one of my biggest complaints about the 10X).
Thanks again and cheers!
Jason
Jason
OK, we set up the 2-aileron, 2-flap wing type. We set the flap control to NULL, and then turned on the Ail->Camberflp mixer. We set the left and right values for Flp and Flp2 to 100%. We then went into the Aileron Differential mixer and set up a differential. This worked out nicely.
If you want to have flap action, then you'll have to set a control for Flap (not Flap2). The middle of the contro's movement will be center for the flaps. Move it one way and flaps go down, move the other and flaps go up.
Set one aileron servo and one flap servo on the L.H. aileron, and then set the other aileron and flap servos to the R.H. aileron.
I'll need to do this for my next plane.
I was thinking I could/would set the 2 Left wing servos to the Ail function, 2 Right wing servos to the Ail2 function.
Then set ATV for each servo/channel.
Won't this work? Seems like Ail Diff should work with this setup too.
My Feedback: (25)
AR
underdw,
I didn't know I could do that. Seems to be the best by far. No reason for flaps on an IMAC plane!
Thanks everyone for responding. Hopefully I'll be able to get this radio up and running for a contest in a few weeks!
Cheers,
Jason
Cheers,
Jason
