Transferring models
RE: Transferring models
A Futaba CamPac can be used to move models from a 9C to a 10C. Just store the models in the 9C to the CamPac, then install the CamPac in the 10C. When the 10 asks if you want to format the CamPac, select 'no' and then you'll be able to use the models in the CamPac. However, some functions may not transfer 'cleanly' because of the differences between the two transmitters.
