Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
2.4 FASST with JR Digitals
Old 04-11-2009, 06:24 PM
dirtypool
Default 2.4 FASST with JR Digitals
I have been trying to find this info online but after pages and pages of search results I still cant find it. So here goes:
I just replaced my 9C with a 12FG 2.4 radio. I have a 100cc Extra that has all JR digital servos in it. 4 8411's on wing and 2 on elev. 8711 on rudder.
Is there a problem with using these servos on my 14 channel 2.4 receiver?
What if I use a servo power isolator? Would that help? I have what appears to be an i4c servo power isolator that was working on the 72mhz receiver.
I installed the new rx and the servos in my right wing were not working normally and the servos seemed to buzz more than I remembered. (I havent flow this plane since last year) I don't know if that was a rx/servo compatibility issue or what.
Would a SmartFly power system work with this receiver?
Or should I just run one relion pack and voltage regulator with everything directly into the rx?
Rob
Old 04-13-2009, 09:19 AM
Bax
Default RE: 2.4 FASST with JR Digitals
Digital servos will buzz any time there's a load on them. That indludes when the model is not flying because gravity tends to pull the elevators and ailerons down.
Old 04-13-2009, 01:14 PM
dirtypool
Thanks Bax.
Do you know which servos do not work with the 14 channel FASST Rx?
Old 04-13-2009, 02:21 PM
Bax
We don't have a list. We only know that some older servos won't work with the R6014FS receiver. Here's the advisory:
http://www.rcuniverse.com/forum/m_7365443/tm.htm
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
