Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
startup delay on one channel FASST
Old 04-26-2009, 02:32 AM
fehringer
Default startup delay on one channel FASST
Hello
I am using an R608FS rceiver with a 14mz/TM14 FASST module and have noticed that sometimes when I turn on the receiver, all the servos centre as they should apart from one elevator servo (S9601) that takes around 2 or 3 seconds longer and then centres/turns on. Is this normal behaviour or is there something wrong? The reason why I asking is because I had "twitching" problems as if there was a problem with one of the elevator servos, but on the ground I cannot really find anything obvious.
Many thanks
Gerhard
Old 04-29-2009, 01:55 PM
Bax
Default RE: startup delay on one channel FASST
We'd not know why one channel would come on line later than the others, unless there's something wrong with the servo. You may wish to check with your service center.
