Futaba 12FG / R6014FS Rx , Y harness
PA
Currently changing from a Futaba 9C PCM to the 12FG 2.4: My problem is when I use a Y harness with 2 servos to channel 4-12 the servos chatter terriably. When I put the same Y harness set up in channels 1 and 2 they work fine. I have tried every thing including dupplicating the condition with a freinds exact system setup. Can anyone out they help? If I seperate 2 servos to seperate channels it will work. This same setup I am trying to acheive worked fine on my OLD System 7 Futaba and my recent 9C, it seems this radio system should be able to do this very easily. Currently running version 1.6
Thanks for listening if you have any ideas don't hesitate.
Thanks Randy
Thanks Randy
