Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
R6008HS Rec and 10CAP Radio, Elevator and Aileron hook up
Old 07-20-2009, 09:18 PM
lnl1950
Default R6008HS Rec and 10CAP Radio, Elevator and Aileron hook up
What are the proper connections and / or programming required to utilize the HS mode of this reciever, to operate 2 channels each for elevator and ailerons? I currently use digital servos (S9252) on channels 1 & 7 for Aileron Differential and channels 2 & 8 for Ailevator. Will this require some form of channel swapping or mixing?
Thanks for your suport,
Larry
Old 07-21-2009, 04:05 PM
Bax
Default RE: R6008HS Rec and 10CAP Radio, Elevator and Aileron hook up
With the 10C, you'll need to do manual mixing so that channels 5 & 6 can be used for the second aileron and second elevator. Be sure to turn "TRIM" on, and be sure to turn "LINK" on if you have other mixes that involve elevators or ailerons. You won't want to use the Aileron Diff or Ailevator mixes to use the HS mode of the receiver.
