12FG how to reverse elevator trim?
got my plane setup with elevons...everything is working great except the elevator trims..... i need to reverse the elevator trim only....how would I go about doing this???
thanks Brian : ) |
RE: 12FG how to reverse elevator trim?
You want to "reverse" the trim...so that when you press the trim button towards the top of the transmitter you get "UP" trim? Opposite of normal operation?
Exactly what are you trying to do? Please give us a better description of what you've done and what you want to do. Thanks. |
right now the trim is working opposite of what would be considered normal.....back stick pulls the elevators up...bumping the trim in the same direction pushes the elevators down and vise-versa...maybe i messed it up by mistake...i would like it to work in the same direction as the stick...IE bumping trim down will move the elevators up like the stick. plane is a delta with two servos operating elevons....thanks for any help
Brian : ) |
Go into the System Menu and then the "H/W Setting" section. Go into the H/W Reverse section and then check the setting for "T3".
All the setting in the H/W Reverse section should be set to "NORM". |
THANK YOU that was what i needed...all were set to norm..i reversed T-2 and now it works the way it should
Best Brian |
| All times are GMT -8. The time now is 02:07 AM. |
