RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   8fg elevons (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/10045536-8fg-elevons.html)
McXtreme 10-03-2010 09:11 PM
8fg elevons
Hello, I'm trying to program elevons on my new 8FG. My 6EX had a setting for it. The 8FG manual seems to make no mention of elevons. I did select the 2 ail flying wing config but i need to reverse the elevator direction. Could someone please fill me in on how to do this? Thanks, Dale
Krysta 10-05-2010 11:07 AM
RE: 8fg elevons
Hi Dale,
Please check pages 53 and 54 of your manual, it will explain to you that for Elevon, you will want to select the correct wing type for your aircraft. Which in your case would be Flying Wing.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
McXtreme 10-06-2010 06:48 AM
RE: 8fg elevons
Thank you Krysta,well it looks like Futaba took the term "elevon" and threw it away. I wanted to reverse just the elevator throw direction without affecting the aileron direction. i could not find that info in the maual. A call to Futaba support and spoke to John. He researched it and called me back with the answer that i needed to reverse just channel 1 or channel 6 depending on which servo is plugged in where.
Dale
