Need some Help Programming a Delta
Hi Guys,
I'm just about to start work on a CARf Rookie II. It is a delta and I need to work out how to program 4 servos (2 on each wing) to work together. Currently I can only get 2 I tried the delta setup with 2 servos and then added the other 2 in the function menu but could not get it to work. Any suggestions?? Radio is the 12FG. Cheers Jeremy |
RE: Need some Help Programming a Delta
Okay sorted it - Selected the 4 x aileron + 2 flap option. Removed the flaps from functions so only the ailerons are left and it is all mixing as should be now in servo monitor.
| All times are GMT -8. The time now is 04:51 AM. |
