10c trim switch circuit board
The left rudder trim switch on my 10 c tx does not work. It clicks but the trim does not adjust.
It is a surface mount switch on a small circuit board with all the other trim switches on it. Is it possible to purchase a new circuit board anywhere? or does anyone know of the part number of a replacement surface mount switch?. It is easy enough to replace., thanks Darryl |
RE: 10c trim switch circuit board
The circuit board you are asking about is not available as a separate item. It comes only as part of the entire transmitter PC board set:
HSP79796 TFT1200885 TB24 PCB ASSY 10CA US$289.38 |
