RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   6014HS Rx battery inputs (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/10470674-6014hs-rx-battery-inputs.html)
3D Joy 04-18-2011 03:39 PM
Quick question here. While getting rid of my Power box/expander, I end up not having enough servo ports on the receiver.
Can I safely use the DG1 and DG2 ports on the receiver as battery inputs or I have to stick with the 12 channels and the dedicated battery port?
I can't see how it would not work but I've been told not to do that for obscure reasons.
Thank you
Meesh 04-19-2011 03:38 AM
RE: 6014HS Rx battery inputs
I'm not sure about the Digital channels but I do know that you can "Y" off of one of the proportional channels for an extra battery input.
Bob
Krysta 04-21-2011 06:41 AM
Yes, you can use the DG channels for battery input if you are running out of room or do not want to use a Y-connector into one of the other channel ports.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
