replacement t/x case required
Does any one know where I can get a replacement case for my 10c t/x ? The rear plastic case on mine is falling apart. The plastic is just falling apart and disintegrating. The handle has fallen off as all the plastic it bolts to has broken up and fallen off, and the upper right hand switch housings are starting to fall apart, as are the retaining screw posts on the front case. I cannot afford to spend another massive amount of money just because the plastic case is inferior to the rest of the product. Darryl</p> |
RE: replacement t/x case required
You should be able to buy the parts you need from your Futaba service center. You can also email us directly for information on the specific parts you need.
Thanks Bill.
We do not have a service centre here in Dubai, so will be emailing you. Darryl |
| All times are GMT -8. The time now is 09:09 AM. |
