RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Timer set up on FUTABA 10c (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/10722591-timer-set-up-futaba-10c.html)
mercuryflyer 09-18-2011 09:28 AM
Can anybody help me please trying to set up timer number 2 on my 10c
I have built an electric glider with twin ailerons and twin flaps so have selected model type as GLID (2A+2F). I want to use timer 2 as a count down for my motor battery pack e.g 6 mins motor run
This timer I want to use on the throttle stick (channel 3), throttle operation starts countdown
When I try and programme this I move down to Swa and use the thumb wheel to try and assign the throttle channel, apart from all the switches I only get STK-ARB
I though I would of seen STK-THR as an option, I guess it is because I have selected GLID (2A+2F) ??? to compound the problem I cannot work out which switch/control channel is the airbrake.
I put the transmitter down now as it is geeting time for tea and I getting more and more frustrated
Thanks<br type="_moz" />
Bax 09-27-2011 06:10 AM
RE: Timer set up on FUTABA 10c
When you use Glider programming, the throttle stick gets assigned to Airbrake (ARB). To keep it as "Throttle", you'll need to use the ACRO menu. You can use that stick to control the timer...why not? How you use the different channels is as arbitrary as you decide.
