9C programming recommendation
I have a new glider, ASH26 from tangent, 4m wingspan, with ailerons, flaps and air foils. In adddition i have a retract landing gear, and optional break, and a tow hook. Plus rudder and elevator of course.
i thought to do the following configuration 1. Aileron 2.Elevator 3.AirFoil (with Y connector and reverse servo if needed) 4.Rudder + Tow Hook 5.Flap 6.Flap 7.Aileron 8.Gear I already have a config for a glider with 2 ailerons and 2 flaps acting as crow with the power stick. Do you think it is OK ? Thks, Pierre |
RE: 9C programming recommendation
If your setup does the job, it's the "right" one.
Here's the 9C FAQ page: http://www.futaba-rc.com/faq/faq-9c.html More help there. |
| All times are GMT -8. The time now is 08:44 AM. |
