8FG Super:Trainer function
Hi,
i just received 8FGS TX.I have question regarding trainer function.Two types of cables are possible to use. Special trainer cable (FUTM4405) has device for voltage reduction and conventional cable has not. 1.May i use special trainer cable for all combination of Tx or i have to buy bought cables? 2.If i must have both cables and if i use wrong one will Tx be damaged? 3.Tx 8fgs has lower voltage than T6EX and if 8FGS is on instructor side (8FGS is supplying T6EX) why we have to use spec. cable?(Instruction manual,page 44) 4.If T6EX is on instructor side and 8FGS is used for student controls,may i use conventional trainer cable? Thanx Danijel |
RE: 8FG Super:Trainer function
You use the special trainer cord in this situation: When the Futaba 8FG or 12FG is used with another Futaba transmitter with a micro port and standard 9.6V battery are used together. Micro connectors on both ends. Fixed directional hookup is labeled "T" for teacher side and "S" for student side to insure proper connection.
You use the regular micro-to-micro cord between two 8FG's or between an 8FG and 12FG. |
Thanx
Danijel |
| All times are GMT -8. The time now is 02:13 PM. |
