6XAS - gear and elevator
Is there any way to mix in Elevator with the Gear switch? I have my flaps on Channel 5 right now so all I have to do is flip a switch and I've got flaps but I need to program in some elevator so my plane doesn't try to shoot up into orbit. I know that the airbrake is normally used for this, but I have it set up this way so I can do a crow-type movement with just 2 switches. Any help would be greatly appreciated. Thanks.
Hi beardking,
Unfortunatley, no, the 6XAS does not have the programming available for what you are wanting to do, you would need either an 9C or 9Z for this type of mixing. I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721. Sincerely, Krysta Lead Futaba Customer Service and Programming Technician Also you may want to check our Website at (http://www.futaba-rc.com) |
| All times are GMT -8. The time now is 12:54 AM. |
