Timer on T18MZ
Hello
I have just purchased the T18 but I have a little problem with the timer. I can't strat the timer directly from the home screen. When I click on it I go in the timer menu. I can't start the timer directly clinking it on the home menu as on the T14. Do you have a method (without a button or a stick of course I know how do it) to start the timer directly from the home screen? Thanks a lot. best regards. Fifou |
RE: Timer on T18MZ
While this is not set up the same as the 14MZ it can be made to mimic it in a way.
You can either just use the Timer screen as your main screen while flying, or you can set the S1, S2, S3 or S4 key to take you to the Timer screen, and while on this screen, you can do as on the 14MZ and tap the timer with your finger to start it. We will pass this suggestion on to Futaba Japan for the next software update. Sincerely, Krysta Product Development & Support Specialist Futaba Service Center USA [email protected] |
RE: Timer on T18MZ
| All times are GMT -8. The time now is 11:06 PM. |
