Throttle cut function
Good afternoon!
I have a 12FGA system where the throttle cut function is activated on the opposite side of my throttle curve,when it is at full throttle for me. I cannot find a way to have the feature at the opposite stick movement. How do I do that? Many thanks for your reply! Michael |
RE: Throttle cut function
The normal operation of the throttle function is to have the engine at idle when the throttle stick is down. The throttle cut will lower the throttle from there. If your engine is at full throttle when you have the throttle stick down, then you are operating your system in a very non-standard manner, and the throttle cut won't work for you.
Hello Bill,thanks for the answer.i probably didn't explain well enough the issue:
when i have full throttle(mode 1) the right stick is fully forward and respectively idle towards me.But the throttle cut function works when the stick is in the max.power position ie full forward. So my question remains:how can i have the function required when the stick in the idle position? Thanks,Michael |
You will need to check the servo reverse function, but also check the Hardware Reverse function inside the System Menu. Maybe the hardware got reversed on the throttle channel. That could cause your difficulty.
Hello Bill,
Thanks for your reply but what exactly do you mean by HARDWARE? I only go to LINKAGE/SERVO REVERSE in the LINKAGE MENU of my T12 FGA. SUPPORT IS APPRECIATED!! Michael |
| All times are GMT -8. The time now is 02:08 PM. |
