9C - Timer Question
Hi All,
Maybe you people can help me with anoother issue. It seems simple but I've not found the answer. In roughly the middle of the LCD screen, it shows "Timer= x:xx" The time is sequencing along ok, but I can't figure out what it's timing or how to reset it. Even after changing battery packs, it's not reset. What is it and how do I change it? Thanks, Mark |
RE: 9C - Timer Question
The default for that timer measures how much time your 9C is switched ON. You can zero it out by pressing CURSOR DOWN once til the timer display is flashing...then press the dial til it zeros.
Ok Squareloop,
Now that's working.. cool ! :D Thanks, Mark |
| All times are GMT -8. The time now is 09:43 PM. |
