RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Futaba T7C Programming Question (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/11367442-futaba-t7c-programming-question.html)
Mjg0808 01-12-2013 07:03 PM
Hi,
I'm trying to dial in a few mixes for my new biplane but I'm having some issues. I'm using dual servos for my ailerons but I don't want to use a y-harness because I believe that it will interfere with the other mixes that I want to use which are Aileron-Rudder and Rudder-Elevator for my knife-edge. From what I understand from the manual, I'm supposed to use channels 1 and 6 for the ailerons but I just can't get them to go opposite directions and I'm pretty sure they have to work properly before the other mixes will work.....Is anyone out there able to explain this whole processincluding the knife edge mixeto me because the manual makes no sense. Thank you in advance.
Krysta 01-14-2013 11:53 AM
RE: Futaba T7C Programming Question
If just one servo is incorrect, have you tried simply reversing this? Do you have Flaperon activated? Do you have Flap trim set?
Please give us more specifics and more information of what programming you may have set in your transmitter.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Mjg0808 01-14-2013 08:02 PM
Hi Krysta,
Flaperon is ON. I have DIFF 0% Ail-2>CH6
FL-TRIM is ON
RT>-100%
>-25%
P-MIX1 CH4>2
RT>-3%
>+3% When I move my rudder left or right, the elevator centers. This mix is a good start for what i'm looking to do so I'm ok with it.
P-MIX2 CH4>6
RT>-9%
>+9% The left ailerons moves up and down when I move the rudder left or right. I'm only looking for this to move up.
P-MIX3 Ch4>1
RT>-9%
>+9% The left ailerons move up and right ailerons move down regardless of which way I move the rudder.
Now this is my first attempt using any of the mixes and I know I'm doing something wrong so please be kind to me. If you need any more info I'll be glad to get it to you.
Thank you,
Mike</p>
