Flap programing on the 9c
Hi,
I have an Ultra Stick and would like to program the flaps to switch "G" where I could have no flaps in the up position maybe 10% in the mid position and 20% in the down position. I'm not interested in the Crow function just flaps. My 9c is new to me and I am a little confused. Thanks[sm=spinnyeyes.gif] |
RE: Flap programing on the 9c
Hi BigSky,
You can do this on the 9C in Pmix 7 which utilizes curves and makes this fairly simple to do. Just go into Pmix 7, turn the mix on, make master Flap and then make slave Flap, you will then need to turn Link On, and make this active on Switch G in the Center/Down position. On the next screen you will be at the curve screen so in the first and second curve position, I would left mine at 0% and then in the third position, I made the percentage 10%, in the fourth one I made my percentage 20% and the last one I left blank. This worked out well for me, you may of course need to change the percentages to suit your application, but I beleive this may be what you are looking for. I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721. Sincerely, Krysta Lead Futaba Customer Service and Programming Technician Also you may want to check our Website at (http://www.futaba-rc.com) |
| All times are GMT -8. The time now is 09:43 PM. |
