How do I do this?
Hi guys,
I have a Futaba 18MZ and I am busy setting up smoke. First - What I want to achieve is to control the smoke with my throttle, but only have it switch on above 35% throttle. In other words I don't want the smoke pump to work when my throttle is less than 35% open. Second - I want to be able to switch the smoke complete off from a two position switch. Third - I want to control the amount of smoke with a normal end point setting. Reason for all this; I fly a turbo prop and don't want smoke oil injected when the turbine is at less than 35% as it may choke the engine at low rpm. Also I cannot have the throttle always switch on the smoke above 35% as I need to open the throttle during the start-up of the turbine and then don't want oil being injected. So as an end result I would like to do the following: - Start my turbine as per normal and pull back to idle. - Then switch on the smoke function without the smoke pump starting up. - When I now advance the throttle past 35%, the smoke pump should switch on and deliver the volume of oil that I had set as maximum, using an end point for the smoke function. I hope my explanation is sufficient, but please ask me to clarify any confusing bits. Thanks for your help. Jan |
RE: How do I do this?
This FAQ was written for th e14MZ, but it applies equally to the 18MZ:
http://www.futaba-rc.com/faq/faq-14mz-q912.html |
Thanks Bax, I'll give it a try.
Bax,
This is not working for me, here is part of the reference that you've quoted: I have made comment in ((brackets)) where I have a problem. You will want to exit the Condition screen now, (leaving your switch set to the Up position as that you remain in Condition 2 and go back to the Function screen in your Linkage menu. This time you will again go to the channel 8 Fuel-Mix (or whichever function you have your pump on) and make sure that both Control and Trim are NULL. (( When I come back to the Function here, the control and trim is still as I had set them in the first place with the first condition - if I now change both to NULL, it also changes both to NULL in the first condition)). Basically what I want to do is the following - please give me specific instruction on how to accomplish this: - I want to use switch SA (which is a 2 position switch on my Tx) to switch the smoke pump on or off (regardless of my throttle stick position - see below). - I also want to use my throttle stick (mode 1 J2) to start the smoke pump (if switched on with SA) at 30% throw and continue it working all the way up to 100% throw. When I bring the throttle back to idle (or below 30% throw) I want the pump to stop. Thank you for your assistance. Jan |
Hi all,
All worked out, please check here http://www.rcuniverse.com/forum/fb.asp?m=11503978 Cheers, Jan |
| All times are GMT -8. The time now is 06:30 AM. |
