T8J Voltage Reading Low
My T8J voltage is reading 0.5v low at the screen. In fact, every T8J that I've looked at does the same thing (6 of them so far). This is the same thing no matter what pack I put in it, NiCad, LiFe, Alkaline, etc... always reads .5v below what the battery pack reads.
It's not a matter of battery under load, if this were the case all of my other Futaba TXs would do the same, but they all read exactly what the batt pack measures. I'm pretty sure this is a defect in the T8J line of radios; can this be fixed with a firmware update? |
RE: T8J Voltage Reading Low
Futaba's been notified of this. Apparently, the voltage sensor is downstream of a control diode or similar component. However, the absolute voltage isn't that critical for proper and safe operation of the system.
Bill,
How does this effect the low voltage alarm? Will it go off too early because the radio believes it's voltage is too low? |
