Vectored thrust set up on 18mz
I have a skymaster turbine Mig-29. Two vectored thrust nozzles, two servos each. I have rudder and elevator set up and just made a condition to zero the ATV in normal flight mode. I have two servos assigned as nozzle 1 and two as nozzle 2. I would like to mix in ailerons as well. I'm guessing I have to split them into 1-4 in order to mix in ailerons? Will that take 6 separate mixes? Can I assign two channels as slave in a mix?
No y-connectors, sbus channels 12-16. |
RE: Vectored thrust set up on 18mz
You can do a few simple mixes: Elevator->Nozzle-1, Elevator->Nozzle-2, Aileron->Nozzle-1, and Aileron->Nozzle-2. You can assign them a single switch to turn the mixes on and off, or have them active within a condition. Since you have two servos assigned for each nozzle, you don't need separate mixes for them.
