148 DF Question
I have a 148Df Receiver that I am using on a UCD46 and I am using CH2 & CH8 to run two servos for the elevator using the Ailevator function. The question is does it hurt to plug the battery into CH7 since one of the elevator servos is plugged into CH8 which is where the battery in suppose to go?
Thanks, Fossil |
RE: 148 DF Question
Hi Fossil,
No, this will not hurt the receiver, you may plug the battery into any of the channel ports you like without worry. I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721. Sincerely, Krysta Lead Futaba Customer Service and Programming Technician Also you may want to check our Website at (http://www.futaba-rc.com) |
RE: 148 DF Question
Thank You,
fossil |
| All times are GMT -8. The time now is 11:46 PM. |
