RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Programming 7C for quad servo wing configuration (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/11585489-programming-7c-quad-servo-wing-configuration.html)
philakapd 08-22-2013 06:21 AM
Hello, I've been dreading this moment for months and it finally arrived...I’ve spent days researching the Futaba, RCU and Google websites trying to find somebody else with the same predicament I have… here is my current setup:
Futaba 7C transmitter with R617FS receiver (7channel).
6 Hitec HS-65MG Mighty Feather Metal Gear Micro Servos.
Hangar 9 Mini Ultra Stick w/ E-flite 480 outrunner and FlightPower 2500mAh 3S LiPo.
CC Thunderbird 54 ESC – I planned on using the internal BEC (rated for 3Amp)
Quad servo wing configuration (2 servos for aileron and 2 servos for flaps)
Channel 1 = Right Aileron?
Channel 2 = Elevator
Channel 3 = Throttle / ESC
Channel 4 = Rudder
Channel 5 = Left Aileron?
Channel 6 = Right Flap?
Channel 7 = Left Flap?
Along with the programming, I'm having a hard time placing the proper servo to the proper channel for this setup.
Here is my programming wish list:
I would like to program my low rate for L/R aileron with the ability to set flaps at 30%. Program my high rate for full wing deflection (L/R aileron – L/R flap synced in unison with 100% throw). Lastly, I would like to “crow”.
To summarize:
1. High Rate - L/R aileron and L/R flap working in unison (full deflection).
2. Low Rate - L/R aileron only (full deflection) with the ability to enable flaps down 30%.
3. Crow.
Is it possible to program my 7C for this configuration? Can I use the 3- position switch for High Rate/LowRate/Crow and use a different switch to set flaps down 30% while using my low rates?
I should be @ 2.4Amps maximum load for the servos. I will use my PowerMatch to verify real-time Amp load conditions once I get the setup programmed and operate all six micro servos simultaneously.
Any help is EXTREMELY appreciated!
Thank You, Clear Skies to All.
-PD
Bax 08-22-2013 07:02 AM
Channel 4 = Rudder
To summarize:
3. Crow.
-PD
This is about as close as you can get:
http://www.futaba-rc.com/faq/faq-7c-q774.html
Otherwise, you'll need "more" transmitter.
philakapd 08-22-2013 07:35 AM
Thank you Bax.
I did locate your link at an earlier date and tried it on my airframe, but it's not the configuration I wanted. I've been waiting to update my 7C and get "more" transmitter with FASSTest. I'm still holding my breath for bi-directional telemetry in a transmitter with less than 14 channels. I've been flying for 20 years and never needed more transmitter until now. I've considered the 14SGA, we shall see!
I appreciate your efforts to this matter!
-PD
