RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   What hardware interface do I need to run jetCat version 10 ECU (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/11628724-what-hardware-interface-do-i-need-run-jetcat-version-10-ecu.html)
mr_matt 04-18-2016 04:27 PM
With the new firmware for the 18SZ?
How do I hook the ECU to the receiver?
Matt
Bax 04-19-2016 07:04 AM
You will have to talk to Jetcat about that. We're not familiar with the product you're asking about.
mr_matt 04-19-2016 04:05 PM
1 Attachment(s)
OK the product I am talking about is the 18SZ, Futaba took the time to add the new software feature for JetCat and i would like to use it.
http://www.rcuniverse.com/forum/atta...mentid=2158152
modtron 04-20-2016 12:51 AM
The "JetCat v10 " Telemetry was produced solely by Robbe for their range of JetCat engines - Ropulsion.
Since Robbe folded, JetCat are unable to supply the adapted ECU's due to legal ownership still being registered with Robbe.
I spoke with Udo at JetCat this afternoon and this was the reply ......
Robbe is gone and the telemetry is not far to supply.
It will become two options
  1. A complete new ECU (same size as ECU V10.0)
  2. A small board to loop in the bus system
The second solution will be the most attractive because the price what is not destined jet.
BTW the telemetry also will be work on Graupner, Yeti, Multiplex and Weatronic.
Best regards
Udo
modtron
Oxford UK
Bax 04-20-2016 06:44 AM
Thank you, Modtron.
To Mr_Matt, we were talking about the Jetcat ECU. We're not familiar with that product. Normally, you'd use a sensor supplied by the maker of the non-Futaba product. Apparently, though, what you need is no longer available. Likely, the software update was well in process when Robbe went out of business, and Futaba decided to complete the update because there are a number of Jetcat engine owners around the world who would want telemetry information.
