Using Futaba 12Z with Aerofly simulator
A friend just bought Aerofly simulator and wants to use it with his Futaba 12Z. He does not have a 72mhz module for the 12Z and can't seem to set up a model in PPM mode to link with the simulator. Does the 12Z require a 72mhz module to output a ppm signal via the trainer port or is it a setup issue?
thanks Woodie |
You need to go into the Trainer section of the Linkage Menu and then set the "TEACHER/STUD" to "STUD" for "Student". When in the simulator, the transmitter "thinks" it's the student unit in a trainer setup. Then, the proper signal will be at the trainer port.
