Sbs-01g, r7008sb, 14 sg
Hello Bax, I was trying to use telemetry with my 14 Sg TX using the SBS-01G and the Rx 7008 sb, I had try everything that the manual says but can’t go through. As soon I plug on the RX, the SBS-01G goes from one second on the red light to the green blink.
I had re link the Rx with the sensor connected to the RX and telemetry ACT. Set the slot to # 8 Wrote the ID sensor # What I am missing??? Regards Erwin Peters |
Anyone would help me?, I took the plane out to the field and I amgetting now the solid Green light but none of the three “G” bars bars for receiving accuracy. :confused:I flew the planbut none results at all for the SBS 01G unit. I am in Ecuador South America; I assumethis unit should work worldwide.
Regards Erwin |
Normally, you install the GPS sensor, put it on the slot desired per the instructions (slots 8, 16, or 24), and then re-link the receiver. It should then work.
If you're not getting good GPS reception (not 3 bars), then you may need to re-position the sensor in the model so that it can receive GPS signals from the satellites. |
