RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   9CAP Super question (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/11638635-9cap-super-question.html)
flyerdave 05-02-2017 02:24 AM
9CAP Super question
I know this is an older technology radio but I just bought one (new old stock). I've just got it and see that it has an FM module on 50mhz channel 00. Hopefully the only change I will have to make to go to 72 mhz will be changing the module to a synthesized 72 mhz module on channel 48 which is the channel all my PCM receivers are on. I hope you will tell me there is no difference in the transmitter itself and only a module swap is needed. Thanks,
Bax 05-02-2017 06:27 AM
You are correct. Only the frequency module is needed.
