16 sz switch programming
As a long time Futaba user WC1 WC2 and other marks of Futaba im at a loss !!!!!!!!!!!!!
Gents could some one please assist with the following in simple terms All i am trying to do is turn on my ignition circiut using a simple rexcell ignition switch in function position 8 motor switch SG selected GR- trim nil GR motor reversed 3 position switch in this case S/G 1st foreward position OFF SAFE 2 nd Middle position OFF SAFE 3rd back position ON RUN I can see the switch changing state using servo monitor AND the LED changing state The first position 1 led indicator off ignition off - SPOT ON endpoint @ 100% Middle position 2 SHOULD be OFF its ON - Wrong !! servo monitor is showing middle position i belive to be 0 setting middle point 3 rd back position is ignition led ON - SPOT ON endpoint @30% In AFR page FUNCTION selected - Motor selected Group GR i have tried to move the centre point to acheive a 30%-40% figure to move the middle point but the switch will not turn OFF in the middle although the switch is correct when activated OFF-OFF-ON i have tried all combinations spline point exp2 expo1 I just dont know were im going wrong Ive set every thing else up works great BUT these dam switches are driving me MAD as we say in the UK im buggerd if i know !!!!!!! Kind Regards to all Dave UK |
I use a point curve.
Make the middle position the same value as the full off position. Make it a flat line from the full off to a bit past the middle position. Then whatever value gives you ON in the third position. |
Bill thanks for the reply only just got back from working away
Well it was a case of brain fade on my part and over confidence with the 16 sz what i was actually doing was pushing the curve the WRONG WAY !!!! this i realised late one night nothing better to do 200 miles away what i actually did was bin the un wanted points of curve which left 3 as you so rightly say top middle bottom. i dropped the middle point to 35/40 the bottom point was at 30 turned on the ignition operated the switches hey presto it worked spot on Thank you for your input - without guys like youself supporting muppts like me loosing the plot thanks again you are a star |
BTDT!!! Glad you got it working.
| All times are GMT -8. The time now is 02:37 PM. |
