Futaba 4PM trigger adjustment screw
Quick question on the Futaba 4PM. I can't for the life of me find the 2.5mm trigger positiona adjustment screw. Any help would be appreciated!
If any Futaba reps are monitoring this, the manual calls the 2mm screw by the trigger two different things. On page 15 it's called the Trigger Slide Adjusting Screw. On page 22 it's called the Trigger Slide Mount and the instructions reference a separate Trigger Slide Adjusting Screw that is a different size (2.5mm vs 2mm).
Sorry, on the road. Let me get the info for you. Sometimes it takes more than an hour at 4:30 am to get to this forum. Thanks.
I'll get back as quick as I can. |
I don'r have one handy. Look at Page 15 on this link:
https://futabausa.com/wp-content/upl...9/07/4pm-e.pdf Are your ou saying yours does not have this screw? It should be fairly easy to get to. |
