9C Programming for 8 servo Operation
The plane that I am building is just a funfly based on the magic / limbo dancer and I dont want to spend the extra money in buying the MSA to split the servos.
I have the 9C, How do I plug and programme all the 8 servos into it. There are 4 aileron servos and 2 for elevator and 2 for rudder...and 1 for throttle. Thank in advance. Regards Marcus |
RE: 9C Programming for 8 servo Operation
Marcus,
Here are a couple links to Futaba's FAQ's on the 9C. There are several more. http://www.futaba-rc.com/faq/faq-9c-q515.html http://www.futaba-rc.com/faq/faq-9c-q29.html I'd probably use a Y-harness on the rudder, and then you'll have enough channels for the 4 wing and 2 elevator servos. Rob |
Are you planning on anything fancy like a Hanger 9 Ultra Stick Quad Flap setup?
If not, then try this: 1) (2) Airlon servos on the right wing Y-connected to channel 1. 2) (2) Airlon servos on the left wing Y-connected to channel 6. 3) (1) Elevator servo connected to channel 2. 4) (1) Elevator servo connected to channel 8. 5) (2) Rudder servos Y-connected to channel 4. A) Activate the FLAPERON function in your 9C B) Activate the AILEVATOR function in your 9C (0% for airlons) C) Be sure you match your rudder servos before installing -- this is easy to do if they are digital and can be programmed (Hitec) D) As with C above, be sure each pair of airlon servos are matched. |
| All times are GMT -8. The time now is 12:25 AM. |
