RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   9CA trim doesn't function on slaved ch. 8 (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/1597103-9ca-trim-doesnt-function-slaved-ch-8-a.html)
Ross Airforce 03-06-2004 04:50 PM
1 Attachment(s)
[:o] I have a Cermark Pitts which requires 4 aileron servos. I have the bottom wing servos y'd into channel 1 and the top wing servos y'd into channel 8. I programmed the radio so that auxiliary 2 (channel 8) is slaved to channel 1 with 100% response and trim turned on. The servos function correctly; however, I discovered this morning that the electronic trim button only moves the channel 1 servos, the channel 8 servos do not follow. Is this normal? Is there something I am missing?
The way it works now, the plane is flyable, but I would like to have trim command over both channels. The programmed sub-trim control works separately for each of the two channels.
Ross Airforce 03-07-2004 10:59 AM
RE: 9CA trim doesn't function on slaved ch. 8
:D:D:DI found out why Aux 2 would not respond to trim and fixed it. The AUX setting for Aux 2 was set to a switch instead of Null. Need to do a mechanical realign of the ailerons and then it will work fine.
Krysta 03-11-2004 03:45 PM
Hi Ross Airforce,
I'm glad you figured it out, sorry I haven't been around for the last few days....other duties called.
Krysta
