RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   9CAP Flaperon function (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/1772655-9cap-flaperon-function.html)
cracker 04-29-2004 10:20 PM
How is it that whenever I activate the Flaperon function and then go to set the percentage of flap movement that the Aileron centering gets changed? I have tried this on several planes and always get the same result. Am I missing something? I referred to the manual and the website with no better results. I don't have this problem on my other radios of a different mfr. I would think that after you have set-up the Ailerons (throws and centering) that when Flaperons are activated that your centering and set-up should not change. So to correct this, I have to redo the Ailerons and constantly go back and forth between the functions until it is good. Any input/advice would be appreciated!
Krysta 05-10-2004 09:17 AM
RE: 9CAP Flaperon function
Hi cracker,
I would recommend that you go into a blank model, set your sub trims and EPA for your aileron and try activating flaperons here. Doing this in a completely blank model will let you know if there is a programming issue involved.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
