Futaba 8 CH programming
Is there a way to use the "gear switch " to turn on another function like proportional brakes on Ch 8 without affecting ch 5 ? ie can I dissassociate the gear switch from Ch 5? Tks
RE: Futaba 8 CH programming
Hi sportflyer,
Yes, this is easy to accomplish by using a Pmix to deactivate the switch. Please check our FAQ's for this radio at: http://www.futaba-rc.com/faq/faq-8u.html This one particularly will help you out: http://www.futaba-rc.com/faq/faq-8u-q52.html I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721. Sincerely, Krysta Lead Futaba Customer Service and Programming Technician |
| All times are GMT -8. The time now is 01:42 AM. |
