8 servo complex aerobatic model setup.
I read the FAQ: http://www.futabarc.com/faq/faq-9z-q205.html and it is helpful but I will be using dual elevator servos so that may arise a problem for me. I do not have the aircraft built yet but want to get the programming in my head to better speed up the setup process. The aircraft will have 1 rudder servo, 2 elevator servos (I would like to use the ailevator function on the elevatos), and 4 wing servos (2 for inboards, and 2 for outboards). I want full-span ailerons and an airbrake function (such as the Ultra Stick) that I can assign to a slider. If possible I would like to be able to use flap trim on either the inboards only or full span flaperons. I know all is possible with the 9Z it's just going to take some thought, I'd like to stay away from chaning condition possibly, but if I have to I guess I can live with it. Any help would be greatly appreciated AM. ;)
Hope to hear from you soon. -Kelly |
Hi Kelly! without taking a radio and some time, I'm not 100% sure, but i believe that the existing FAQ is all you need, simply add ailevator to the setup and, if necessary, adjust the FAQ to allow for the second elevator servo to be in the proper port.
I'll give it a shot. ;)
Thanks again. :) -Kelly |
| All times are GMT -8. The time now is 11:19 PM. |
