Lost Flap Elevator Mix
After getting the crow feature to work I lost the Flap Elevator Mix . I have a 9c FM Ultra Stick flaps plugged into ch 7 and Sw G. The flaps go down but the elevator doesn't. Any idea what I did...thanks :(
Hi, HiFlyer,
Are you saying that your mix in the C up position is gone? sorry, not sure i understand the question... |
HiFlyer, you CAN still have an elevator to flap mix, and simply assign that mix to G with your other mixes....
AM...Thanks for the response....Just tried the elev to flap mix and when I do the ailerons move which brings up another question. The book on page14 shows ch 6 as spare/flap but the Futaba FAQ says to plug the left ail into ch 6 for the Airbrake feature which is what I did. Could this be the reason for the aileron to work in the mix assign. I also have smoke plugged into ch 5. Flaps are plugged into a ' Y ' connector into ch 7. Thanks again.
Well I must be doing something wrong because I still can't get the elevator to move when I flip the G switch. The flaps move up and down but I can't get the elevator mix to move the elevator at the same time. Could you give me an idea what I am doing wrong.. I mentioned above how my receiver is plugged. Do i need to plug the flaps into seperate channels??? :confused:
HiF! Your radio sees 1 and 6 as flaperons = FLAPS. You dont want a flap(eron) to elevator mix, you want a ch 7 to elevator mix. use a blank mix, master is ch 7, slave is ch 2.
| All times are GMT -8. The time now is 05:11 PM. |
